  3. Domoticz
  4. RGB LED strip amplifier gives inverted RGB value
6 Posts 2 Posters 4.0k Views 3 Watching
  • ChakkieC Offline
    ChakkieC Offline
    Chakkie
    Hi all
    Insteads of using three Mosfet, I have connected my RGB led strip with my arduino using a RGB mini amplifier (see below). Since it is smaller and you don't have to solder any wires. I am able to control the led strip in Domoticz but the only problem is the RGB value is inverted. So when you choose blue in the colorpicker the led turns yellow. When you dim the light to 10% it is at its full brightness and when you set the level to 100% it turns off. (So the values are inverts). I have tested with a single dimmable led strip and it gave me the same result. It looks like that this module works as an inverted Mosfet.
    Anyway I was wondering if you can solve this problem by modifying the script I am using. Like may be inverting the value.
    This is the script I am using
    #define RED_PIN 3
    #define GREEN_PIN 5
    #define BLUE_PIN 6
    #define NODE_ID 70
    #define CHILD_ID 0
    #define SKETCH_NAME "RGB_STRIP "
    #define SKETCH_VERSION "1.0.0"
    #define NODE_REPEAT false
    long RGB_values[3] = {0, 0, 0};
    float dimmer;
      pinMode(RED_PIN, OUTPUT);
      pinMode(GREEN_PIN, OUTPUT);
      pinMode(BLUE_PIN, OUTPUT);
      gw.begin(incomingMessage, NODE_ID, NODE_REPEAT, 0);
      gw.sendSketchInfo(SKETCH_NAME, SKETCH_VERSION);
      gw.present(CHILD_ID, S_RGB_LIGHT, "RGB Strip", false);
      gw.request(CHILD_ID, V_RGB);
      gw.process();
      if (message.type == V_RGB) {
        String hexstring = message.getString();
        long number = (long) strtol( &hexstring[0], NULL, 16);
        RGB_values[0] = number >> 16;
        RGB_values[1] = number >> 8 & 0xFF;
        RGB_values[2] = number & 0xFF;
      if (message.type == V_DIMMER) {
        dimmer = message.getInt();
        analogWrite(RED_PIN, int(RGB_values[0] * (dimmer / 100)));
        analogWrite(GREEN_PIN, int(RGB_values[1] * (dimmer / 100)));
        analogWrite(BLUE_PIN, int(RGB_values[2] * (dimmer / 100)));
        if (message.getInt() == 0) {
          digitalWrite(RED_PIN, 0);
          digitalWrite(GREEN_PIN, 0);
          digitalWrite(BLUE_PIN, 0);
        if (message.getInt() == 1) {
    Raspberry Pi 2
    Domoticz
    RFXCOM
    ZWAVE Aeon stick
    Coming soon Arduino mysensors GW
    TheoLT 1 Reply Last reply
    • ChakkieC Chakkie
      Hi all
      #define RED_PIN 3
      #define GREEN_PIN 5
      #define BLUE_PIN 6
      #define NODE_ID 70
      #define CHILD_ID 0
      float dimmer;
        gw.process();
      TheoLT Offline
      TheoLT Offline
      TheoL
      @Chakkie Hmmm it sounds odd. But if the software part can easily be changed. I'm not able to test it but this is what I would do. I'm not gonna modify the complete sketch. But I'd use an unsigned byte as the storage type for the RGB values. It uses less memory, but that's the only reason.
          RGB_values[0] = 254 - ( number >> 16 );
          RGB_values[1] = 254 - ( number >> 8 & 0xFF );
          RGB_values[2] = 254 - ( number & 0xFF );
        else if (message.type == V_DIMMER) {
        else if (message.type == V_LIGHT) {
          analogWrite( RED_PIN, message.getBool() == true ? 0 : int(RGB_values[0] * (dimmer / 100)) );
          analogWrite( GREEN_PIN, message.getBool() == true ? 0 : int(RGB_values[1] * (dimmer / 100)) );
          analogWrite( BLUE_PIN, message.getBool() == true ? 0 : int(RGB_values[2] * (dimmer / 100)) );
      I've refactored the code a bit. As said I can't test it and haven't compiled it. But I hope it works and that it'll help you a bit in the good direction.
      ps. I didn't like soldering in the beginning but once you've mastered it is - to me at least - more satisfying to solder my own projects.
      Anyway good luck with it
      ChakkieC 1 Reply Last reply
      • TheoLT TheoL
        ChakkieC Offline
        ChakkieC Offline
        Chakkie
        @TheoL
        Thank you so much TheoL. With your help I have added the 254 value as you told me. Once uploaded I can see that the color is closer to color I picked. So I have changed 254 to 255 and yes I 've got the right color. Now comes the next problem. I can no longer dim or turn off the led strip. When ever I choose the white ffffff or black 000000. The led stays at it full brightness. I guess we are close but only a little more tweak.
        Thanks you so much
        Raspberry Pi 2
        Domoticz
        RFXCOM
        ZWAVE Aeon stick
        • ChakkieC Chakkie
          @TheoL
          Thanks you so much
          TheoLT Offline
          TheoLT Offline
          TheoL
          @Chakkie What happens if you turn the light off? I'd be expecting a V_LIGHT....
          • TheoLT TheoL
            ChakkieC Offline
            ChakkieC Offline
            Chakkie
            @TheoL
            Hi TheoL, When I turn off the RGB, the ArduinoIDE serial Monitor gives a sg=0:0. See image below. And as you mentioned. I don't see the V_Light respond. See image.
            ![alt text](0_1459696736731_upload-84afe10a-7f2a-475e-bafb-fe84a4dc7049 0_1459696705265_upload-4c5475c9-23db-4517-8c2c-aae77d081a57 image url)
            ![alt text](0_1459696766153_upload-743804b2-8e2f-4d66-992d-12f433216cfa image url)
            ![alt text](0_1459696825659_upload-3ed10e3f-4f2e-4b21-84ee-c4d3cb6cdd21 image url)
            Raspberry Pi 2
            Domoticz
            RFXCOM
            ZWAVE Aeon stick
            • ChakkieC Offline
              ChakkieC Offline
              Chakkie
              wrote on last edited by Chakkie
              Hi TheoL,
              I have changed the value from 0 to 255 as shown below and now the LED strip turn off when I click the off button in domoticz.
              Now the dimming part has yet to be solved :)
              ![alt text](0_1459697790250_upload-deea4aa9-4d91-4afa-af88-b87a342aed1e image url)
              Was
                    digitalWrite(RED_PIN, 255);
                    digitalWrite(GREEN_PIN, 255);
                    digitalWrite(BLUE_PIN, 255);```
              Raspberry Pi 2
              Domoticz
              RFXCOM
              ZWAVE Aeon stick
